Steering Wheel Spacer
Phantom
Only option I can think of with the stock wheel would be to sacrifice another wheel for its splined base.
Removing the arms and drilling/tapping the extra base would allow you to attach your wheel (which would also need to be drilled) in the same fashion as an aftermarket wheel.
You could probably use a trimmed rubber MOMO hub adapter cover to cover the whole assembly too?
