beon Posted December 14, 2014 Share Posted December 14, 2014 Photos can be seen via the link below. I've attached two pics which show the car as it was on the day I purchased, and how it sits now. The car has been almost completely restomodded less completion of the paint, EFI, audio, and A/C. Pics tell the story. https://www.facebook.com/media/set/?set=a.2907404131179&type=1&l=a396af60a3 1974 260z JTR v8 SwapContributors: You (owner) and Bruce Kraft Updated about 8 months ago PublicFriends of ContributorsContributors Only Car: Early(January)1974 Datsun 260 Original Paint Code 305 : Light Blue Metallic. Or Possibly 307 Pacific Blue MetallicReplaced Floor PansAdded sub-frame connectors (Pete's Design)Suspension:Tokico Blue Shocks in frontKoni Adjustables in RearMSA Lowering Springs Urethane Bushings throughout MSA Sway Bar KitCamber Adjustment Kit on front and rearEngine:Early High Nickel 350 Chevy Block (Less than 2,000 Miles on rebuild) Bored .030 over / Complete Machine Work Completed at Lucito's Machine here in town(No - Cracks) Edelbrock RPM Aluminum Heads & Intake Summit Alum Valve CoversAlum 1.5 Roller Rockers Edelbrock 400 Cam Edelbrock 600 Carb Summit PistonsAlum Water Pump MSD Distributor/8.5 Wires/Blaster 3 CoilHigh Volume Oil PumpShorty HeadersBrand New JTR (Z28) Radiator W/ Custom built shroud & custom upper radiator hoseCustom Dual Exhaust / Magnaflow MufflersEst 300+HP/~400TqTrans: World Class T-5 Hardened Cobra (Mustang) Gear set (from TheGearBox.org)Completely rebuilt, everything is new, Bearings/Syncros everything. New RAM Pressure Plate and FlywheelNew Tilton Master and Hydraulic Slave Hurst Shifter Brakes:New Master CylinderNew Vaccum Booster!!!Toyota 4 Piston Brake conversion up frontRear-end: R180 Rear open Diff Wheels: Rota Rb in front 17x7.5 and Rb-R in rear 17x8.5Other: RX-7 SeatsPainless Wiring Harness RCI Fuel Cell Have most interior pieces Have NEW grey carpet set Bolt In (4point) Roll BarFull Set of AutoMeter Phantoms Gauges (Speedo/Tach/Vac/Oil/Temp/Fuel)Oil Pressure Gauge is wired w/ copper from gauge to motormany more other parts for the car including some A/C parts Quote Link to comment Share on other sites More sharing options...
beon Posted December 14, 2014 Author Share Posted December 14, 2014 Pics attached: Blue = when bought from Bill. Black = current/ repainting original color. Quote Link to comment Share on other sites More sharing options...
