daryl_db Posted December 22, 2014 Share Posted December 22, 2014 I just installed the Arizona Z Car 5 lug brake kit on my 73 240z and now Im trying to figure out what rims to get. The car has coilovers installed. I'm looking at a set of 17 X 8.5 with a 25mm offset. Will this work for both the front and rear? Please let me know what you guys with the same setup are running. Thank you Daryl Quote Link to comment Share on other sites More sharing options...
nullbound Posted December 22, 2014 Share Posted December 22, 2014 (edited) There are a few people with that same AZ Z 5-lug kit that have ran 17x9 with 35mm offset on the rear. I saved this thread a while back when considering 17" wheels for a 240: http://forums.hybridz.org/topic/71868-arzs-build-thread-1971-240z-7mgte-487-rwhp/ He mentions these sizes for his wheels in that thread: 5 Zigen 17x9 x35mm offset for the rear and 17x8 x 25mm(or 15mm I cant remember) for the front. In another thread he recommended 35mm for the fronts instead, but I can't seem to find that off hand. Edited December 23, 2014 by nullbound Quote Link to comment Share on other sites More sharing options...
daryl_db Posted December 23, 2014 Author Share Posted December 23, 2014 Thank you for the reply Nullbound. Quote Link to comment Share on other sites More sharing options...
Savage42 Posted December 23, 2014 Share Posted December 23, 2014 My guess is that there are some spacers or adapters being used there, as well, so that doesn't tell you what the real offset (needed to fit) would need to be to fit that wheel. I'm looking at a set of 17 x 8 wheels (built to any offset I want), so I have to play around with the best offset that would require only a set of spacers on one end, if possible. This would be under stock, rolled fenders. I currently have 16 x 8 wheels with adapters (due to the FWD offset) and want dished wheels. Quote Link to comment Share on other sites More sharing options...
nullbound Posted December 23, 2014 Share Posted December 23, 2014 He mentioned the 5 lug AZ brake kit, though, which pushes the the wheel mounting surface out around 3/4" on all corners. The links I posted were specific to another user with the same kit. Quote Link to comment Share on other sites More sharing options...
Savage42 Posted December 23, 2014 Share Posted December 23, 2014 Gotcha, so effectively adding a 19mm differential to the actual offset of the wheel. That makes more sense, as I was wondering about how those numbers would work under stock fenders without spacers. Thanks for the clarification. Quote Link to comment Share on other sites More sharing options...
nullbound Posted December 23, 2014 Share Posted December 23, 2014 I should have been clear from the start. I made an edit to my original response for others who may read this thread. Quote Link to comment Share on other sites More sharing options...
