batch fire wiring options?
bahelion89
alright i understand that when wiring your injectors for batch fire they are wired in 2 sets of 3 injectors.
My question is how are you actually wiring them? 3 injectors to 1 wire and then a jumper at the db37? or 1 injector to 1 pin and 2 injectors to the other pin?
Pics would be great
because with what i have shows wiring 3 injectors to a single wire
Thanks!
In my experience with Megasquirt, there is work arounds with the DB37 and its lack of gauge to handle power. If you notice how many grounds there are, since most relays are ground activated. The two pins for each bank of injector are tied together inside the board and go through two pins, I would assume, to handle the power of actuating up to four injectors. So with that said, just tie both pins together after the DB37 connector and branch them out at the injectors. The DB connectors really my only complaint about Megasquirt, but thats my opinion.
