Question on drastically lowering an s30
Hi I have a few questions on what is needed to go very low with my 280z, I'm not new to the stance game at all, but new to the s30, I've done quite alot of research on the subject but no definitive answer. My coilovers are ordered and I'm in the process of ordering front lca's from ttt, and rca's. My question is, Do I need the rear lca's and control rods aswell?? any help is greatly appreciated.
Prefrerably, coilovers that you can weld onto the spindle, or you would need to section the strut housing. If you went with the TTT option so you will most likely have to section the stuts. You didnt mention roll center adjusters or camber plates, You might want them if your trying to go really low. As RebekahsZ mentioned all you "need" id the coilovers. The rear LCAs and other mods will get you a better allighnment once the car is low.
All the info you need and more, is on here.
Welcome, good luck, and post some pics of your car.
