blu240z Posted April 13, 2015 Share Posted April 13, 2015 I've searched and read a lot of posts on this an I'm still confused. I have a 2004 z06 ls6 engine and from my understanding i have to use the 98-02 fbody alternator bracket, water pump, and harmonic balancer ? Also can I use the 2004 z06 alternator ? Quote Link to comment Share on other sites More sharing options...
LS6240z Posted April 13, 2015 Share Posted April 13, 2015 i have a LS6 from a 2004 cts v. . the camaro braket will not work bec the spacing on the pulley are different. i bought a alternator braket from Dirty Dingo and relocated on the driverside top. . but if you have a stock corvette alternator braket that might work for you since its a top mount alternator and i dont see why you cant use your own alternator. . as long as the engine harness is the same it should fit. i think the camaro alternator only has one wire connecton. the LS6 has a two wire. hope it helps. Quote Link to comment Share on other sites More sharing options...
blu240z Posted April 14, 2015 Author Share Posted April 14, 2015 every post I've read says the alternator will hit the shock tower, do you have any pics of your set up you could post ? Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted April 15, 2015 Share Posted April 15, 2015 You should be able to if it keeps the same placement as the Ls1 stuff, to the best of my knowledge it does. Quote Link to comment Share on other sites More sharing options...
