Hood clearance on other than stock intakes
Just wanted to post up my latest intake, so you guys have ideas of what we can use. This is a GMPP ls7 intake with the 6061.com LSX elbow on it. It clears the stock hood without issues. (quite a bit more room, possibly 2" of space)
  On 5/18/2015 at 4:41 AM, Phantom said:
Who's engine mounts are you using? I have JCI mounts and I don't think that set-up would clear my hood. It looks like it's 3-4" higher than a stock LS1 intake manifold.
JCI. It is 3-4" higher than an ls6, but only in the center, where the stock hood is significantly higher than that.
  On 5/22/2015 at 9:48 PM, zspeed22 said:
Now how about if you have a throttle body coming forward, and a 3 inch pipe off of it do you still have clearance forward? Does look really cool as it sits.
Not sure. I go home tomorrow, so I'll see if I can figure it out
  On 5/27/2015 at 3:52 PM, torqen2k1 said:
The Holley high rise intake, the mid rise should clear though.
Should clear? do you know for sure. I have an LS1 intake that I want to swap out for the midrise but I think it will hit not just the hood but hood latch
The mid rise im pretty sure, but I can't confirm if it will clear the hood latch as I cut it off. I am also using hawks mounts to. Sorry about the pictures being sideway. The last picture is with the edelbrock high rise intake.
Darek
