Duff Posted June 30, 2015 Share Posted June 30, 2015 I have an engine and transmission out of a 83zx to put in a 240z. While I have the engine out of the car I want to replace the clutch,pressure plate and flywheel.The clutch and pressure plate because now is a good time to replace them , and the fly wheel because ring gear teeth are damaged. I realize I can replace just the ring gear,but. there seems to be ,at least on EBay, more options that fit the 2+2 than the base coupe. My question is ,if I replace all three will the larger diameter components of the 2+2 (240mm vs 225mm) work? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 30, 2015 Share Posted June 30, 2015 On 6/30/2015 at 12:21 PM, Duff said: My question is ,if I replace all three will the larger diameter components of the 2+2 (240mm vs 225mm) work? Yes, the 2+2 clutch/flywheel assembly will fit. Quote Link to comment Share on other sites More sharing options...
Duff Posted June 30, 2015 Author Share Posted June 30, 2015 Thanks,I thought it would, just wanted confirmation before I ordered the parts. Quote Link to comment Share on other sites More sharing options...
Duff Posted July 9, 2015 Author Share Posted July 9, 2015 I have a follow up question. While doing some more searching I found on another Z site a statement that I would need to use a different release sleeve when I change to the 240 mm set up. Is this correct? I would hate to button this up and install the motor and transmission In the car only to find out I needed to do this. Quote Link to comment Share on other sites More sharing options...
Kurbycar32 Posted July 9, 2015 Share Posted July 9, 2015 Yes you do need to account for some changes there. I used a larger clutch sleeve that has a removable bearing Quote Link to comment Share on other sites More sharing options...
Duff Posted July 10, 2015 Author Share Posted July 10, 2015 (edited) Thanks, I did some more parts searching and found Nissanpartsdeal.com that had parts diagrams and numbers and a way to check if the part you are ordering will fit your application. The 240mm setup comes with the 2+2 so I ordered the sleeve for the 2+2. The part number is 30501-k0400 incase any body else is looking. Edited July 10, 2015 by Duff Quote Link to comment Share on other sites More sharing options...
