98blackbell Posted July 4, 2015 Share Posted July 4, 2015 (edited) Now that we are putting the motor back in, want to make it cleaner routing wiring etc. How and where have you run your grounds to? I had most of ours run to the top tranny engine bolt. That was about 10 grounds. Setup is MS3PRO. This build blog is under tooquick260. Edited July 4, 2015 by 98blackbell Quote Link to comment Share on other sites More sharing options...
dexter72 Posted July 4, 2015 Share Posted July 4, 2015 What i did and i copied another members idea. Get yourself a grounding block from Home depot or Lowes. Mount it, Then run all your M..S. sensor grounds, a large battery ground wire to the grounding block, and another large ground wire from the engine to the grounding block. I also ran another large ground wire from the engine to a frame rail. I mounted the grounding block, so you can only see it if you open the drivers side inspection lid. Ends up being really clean looking. Never had any reset issues. Quote Link to comment Share on other sites More sharing options...
Namor Posted July 4, 2015 Share Posted July 4, 2015 What i did and i copied another members idea. Get yourself a grounding block from Home depot or Lowes. Mount it, Then run all your M..S. sensor grounds, a large battery ground wire to the grounding block, and another large ground wire from the engine to the grounding block. I also ran another large ground wire from the engine to a frame rail. I mounted the grounding block, so you can only see it if you open the drivers side inspection lid. Ends up being really clean looking. Never had any reset issues. Would you mind posting a picture or a link to the product you used? This is something I have been considering doing but wasn't sure how I wanted to do it. Right now I have a ton of stuff running to a single ground point and it is a pain if I need to remove one. Quote Link to comment Share on other sites More sharing options...
98blackbell Posted July 5, 2015 Author Share Posted July 5, 2015 Great idea. Since we moved the battery any ways I can put the grounding block in that service area. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted July 5, 2015 Share Posted July 5, 2015 (edited) I don't have a link but let me see if i can post a pic. Ground bar. Home Depot or Lowes. In the wiring/ electrical box isle. They come in a few different lengths. Around $10 bucks. Edited July 5, 2015 by dexter72 Quote Link to comment Share on other sites More sharing options...
mobythevan Posted July 7, 2015 Share Posted July 7, 2015 If you have any high voltage grounds like LS1 coils have, then ground them as short as possible to the engine. Don't run those ground wires back through the harness next to other wiring or you will get noise coupled into sensors. Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 8, 2015 Share Posted July 8, 2015 Look at my MS3x install thread Quote Link to comment Share on other sites More sharing options...
