WTB: L28 Cylinder Head in Vegas area.
johnnyddn
P90 and N47 have different size combustion chambers.  N47 gives a higher CR than P90.  In case you were looking for a direct swap.  P90 on dished pistons is the turbo CR.  P90 on flat tops is stock.  N47 on flat-tops is "performance".
It will run on the lower CR, it's been onde.  Just thought you should know.  You saw my post on other possible effects though, right?  If the head's corroded, other parts might be also.  Corrosion is usually from running water without antifreeze.
