drawz Posted July 30, 2015 Share Posted July 30, 2015 Hi, Maybe this have been covered before, but can't find any answers.. I'm planning on buying Rota RBR 17"x7.5" front and 17"x8.5" rear with +4mm offset all around. I'm also doing a 1.25" drop. and ZG flares in the future (I belive I need some spacers to get them flush with the flares?) My question is, what size tiers should I go for? I want them to be as wide as possible with no rubbing issues. Thanks. And sorry if I ask for something that already has been covered.. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted July 30, 2015 Share Posted July 30, 2015 That really depends on the suspension setup you have. Are you running a lot of camber? are you going with the stock size ZG flares? How high up are you cutting on the stock metal fenders? For those widths, I'd run a 225 up front and a 245 in the rear, and then make them fit using spacers. You will absolutely need spacers. Most people run 17x9 -13 and 17x9.5 -19 rota RBR's and they fit sorta flush with flares and no spacers. So you'll basically going to have to add 1" spacers. Quote Link to comment Share on other sites More sharing options...
