1JZGTE harnesses back in stock!
Our popular 1JZGTE Pro Series wiring harness is back in stock and ready to be shipped. This harness sold very quickly after our last production run so act fast and get yours now before they sell out again!
Prices start at just $849.
This harness is designed with the highest quality standards in mind and acts as a direct drop in, plug and play wiring solution for a variety of applications. It also supports many ECU, injector and MAFS types and comes built in with quick disconnects to allow you to easily change your setup.
Pro Series Harness Features:
Plug and play
No cores or additional wiring required
Point to Point continuity tested on every wire
Constructed using OEM connectors and seals
Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing
Wrapped in lightweight nylon loom with -94C to +257C operating temperature
Improved grounds
Quick disconnect MAFS/AEM/Haltech/PFC Speed density extensions (change from MAFS TO AEM/Haltech in seconds)
Coil and knock sensor sub-harnesses
Transmission harness with reverse and speed sensor wiring
Alternator charge cable
Retains factory A/C, fans, speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers
Edited by wiring specialties
  • 1 month later...
