Wolf V500 Trigger & Sequence Problem
mrECU
Hello,
I'm newbie at this forum. My name is Joan. Nice to meet you!
I have a problem with Wolf V500 EMS. I'm building S50B32 BMW M3 engine and I wired up all connectons but cannot start the engine. I want to use only 60-2 Trigger wheel. But i cant start the engine. Can anyone help me? Any base maps or screenshots from Ref-Sync Sequence?
Connect the yellow wire to the starter solenoid.  Put some fuel in the tank.
"cannot start the engine" could mean that you lost the key.  More details needed.
Sorry, you're right!  :rolleyes:  :rolleyes:
Trigger&Sequence Settings:
RPM Calibration: 6CYL,3Ref/Rev
Trigger Mode: Reference+Sync
Ref:Multitooth Sync:Missing Tooth
Velocity Tracking Rate: 2
Dual Pulse Window: 3
Missing Tooth Thresold 1/2: 4
Number of Teeth:58
Ref/Sync Offset: 7
Ref/Sync Skip:19
Missing Teeth:2
Trigger Reference: 86 Degrees
Polarity: Falling Edge
Input Type: Reluctor
Injection Sequence: 0,1,2,2,1,0 Pulse Skip: 5
Ignition Sequence: 2,0,1,1,0,2 Pulse Skip: 5
When cranking the engine its popping-farting or garking.
