Dat73z Posted August 23, 2015 Share Posted August 23, 2015 (edited) Hi all, I am currently running the full T3 coilover setup with the Koni Shocks and Ground Control Coilovers. For both the front and rears I am running the stock tophats with enlarged centerhole to slip over the larger piston diameter with the Koni's. Everything bolts together great, but I had a Q on the fronts which I couldn't find detailed in my FSM. With the strut steering bearings installed should the piston shaft be able to turn independently of the tophat with no load (e.g. coil turned down without preload on the shock)? Given that I had to enlarge the centerhole to clear the Koni's there is no locating indent on the tophap anymore so my options to apply torque on the tophat nuts are as follows: 1) Load suspension and torque by hand 2) Quick rap with the impact gun With the tophat nuts torqued down just handtight and absolutely no load on the shock the entire assembly feels fused. I'm thinking I need to torque the tophats on tighter than hand tight and this may change when there is load on the assembly (e.g. weight of the vehicle on the suspension). Edit- Also, anyone who is running coilovers or the same/similar setup, what sort of torque do you recommend for the tophats? Front/Rear? Thanks! Edited August 23, 2015 by Dat73z Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 23, 2015 Share Posted August 23, 2015 I go: "Braap!" with my impact set on low. If you have koni shocks, set the adjuster to mid-travel in the adjustment range as the impact will jam the adjuster if it is set full hard or full soft. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 24, 2015 Author Share Posted August 24, 2015 Sounds great and thanks for the advice regarding the adjusters, did not think of that. Quote Link to comment Share on other sites More sharing options...
