Guest Frank280z Posted May 23, 2000 Share Posted May 23, 2000 I installed one of these in my Z. Now I am very much concerned with the heat tolerances of this type of fuel cell. I wish to run a muffler on each side. Will the heat be too much or not enough to worry about? If so should I just use a heat mat from DEI? Frank280z Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 24, 2000 Share Posted May 24, 2000 I have the aluminum RCI unit and have the same concern. I put the dei matt between the cell and the muffler on the right side and have no heating issue now with the tank. So I guess the answer is, should be OK with the DEI matt. Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
