DeLorean Posted December 21, 2015 Share Posted December 21, 2015 (edited) I purchased a set of Hella Vision Plus 7 headlights for my S30 a few months back and have just gotten around to installing them. The issue I'm running into is fitting the light into the headlight bucket, it sits fairly far out (about a 1/4") due to the tabs on the side of the light being way longer than my previous set. The headlight retainer ring starts to bend when I try to screw it down, it just can't get close enough because of those darn tabs on the light. Does anyone here have experience with the same model headlight, or a similar issue with a different light? It seems like a bad idea to install the light with that much of a gap since water would get in pretty easily. Here are some photos that try to capture the problem: Edited December 21, 2015 by DeLorean Quote Link to comment Share on other sites More sharing options...
mehas240z Posted December 24, 2015 Share Posted December 24, 2015 (edited) Hello, Yes, I had this exact issue. The tabs as you see have 2 levels, a long and short. I nipped off the short one and was left with the two longer tabs on each side. I just bent them inward and instead of having a squared tab shape, I now have what looks like two triangles. Fit fairly decent, a little loose but you can make up the slack by tightening or a piece of foam etc. I am at work but I will post pics of exactly this when i get home, 3-ish hours. But for now, my tabs look like this /\/\ instead of the default squares. -Brian Edited December 24, 2015 by mehas240z Quote Link to comment Share on other sites More sharing options...
mehas240z Posted December 24, 2015 Share Posted December 24, 2015 (edited) Sorry, guess I don't have a picture. I hope what I said makes sense. I just cut the smaller part of the tab and pushed the wider part in towards eachother and formed a triangle. Bam! I had it Hope this helps. -Brian Edited December 24, 2015 by mehas240z Quote Link to comment Share on other sites More sharing options...
DeLorean Posted December 28, 2015 Author Share Posted December 28, 2015 That is brilliant, thanks for the suggestion. I was considering doing something along those lines, so glad to know it works well. Thanks a ton for the help! Quote Link to comment Share on other sites More sharing options...
