Klmykvl Posted December 26, 2015 Share Posted December 26, 2015 Hey all, Just wondering if it would be safe to use a 1/8 watt 1k resistor as opposed to a 1/4 watt as a pullup from my distributor on my l28et. I have a 1/8 watt handy, if not I'll be heading to the store tomorrow. Just curious. I found this suggestion on diyautotune.com http://www.diyautotune.com/jwplayer_viral/images/cartech_articles/280zx/280zxt_v3_igbt_wiring.jpg Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted December 26, 2015 Share Posted December 26, 2015 I used a 1/8 watt. A pull up resistor doesn't use much power. I have using my setup for about 5 years now. Quote Link to comment Share on other sites More sharing options...
Klmykvl Posted December 26, 2015 Author Share Posted December 26, 2015 Thanks for you input. Saves me a trip to the electronics store. Quote Link to comment Share on other sites More sharing options...
Namor Posted December 30, 2015 Share Posted December 30, 2015 The reason a 1/4 watt is recommended is because a 1k resistor with 14 volts applied will flow .014 amps, which is equal to .196 Watts or about 1.5x what an 1/8 watt is designed to handle. The 1/8 watt will certainly work short term, but keep in mind that you will be overheating it. Personally, I would swap it out just to prevent any issues in the future. Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted January 1, 2016 Share Posted January 1, 2016 But the internal resistance of the Megasquirt will limit the current. The pull up is there to make the controller see a high. That pull up should never actually short to ground. I used 5v for my pull up though. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted January 5, 2016 Share Posted January 5, 2016 Actually, the distributor's optical sensor will short the resistor to ground. I'd use 1/4 watt for reliability. Quote Link to comment Share on other sites More sharing options...
