74Adam Posted January 2, 2016 Share Posted January 2, 2016 This is in regards to a 78 model and I am referring to the hole that is under the washer tank and clutch master cylinder. I have a car that someone else installed a megasquirt but they just ran the wires, O2 sensor cable and MAP line through that hole without any effort whatsoever to seal it. MSA sells a reproduction grommet but of course I would have to disconnect all the wires and re-run them through the hole. I live in an apartment complex so I don't like to work on anything that is too involved so would rather not do that at this time. So I'm just wondering what people on here have done to address this? thanks Quote Link to comment Share on other sites More sharing options...
fyanrudger Posted January 2, 2016 Share Posted January 2, 2016 There's split grommets on Jegs/Summit that you can rivet in place without removing the wires. Quote Link to comment Share on other sites More sharing options...
johnc Posted January 3, 2016 Share Posted January 3, 2016 3M 08578 Black 1' Strip Calk https://www.amazon.com/dp/B000PEZ1L4/ref=cm_sw_r_cp_awd_5IhIwbTBH6H0B Quote Link to comment Share on other sites More sharing options...
74Adam Posted January 3, 2016 Author Share Posted January 3, 2016 Thanks John, I knew there was a product like that I just didn't know what to call it. I kept searching for removable putty. Quote Link to comment Share on other sites More sharing options...
