Need feedback on cranking pulsewidths and ASE
74Adam
This is a 78 with a 3.0 N/A stroker, 9.7:1 CR and a mild cam. Running MS2, fuel only, with OEM N/A injectors; OEM pump/filter/pressure regulator and the stock throttle body that I modified to be able to use the 240SX TPS. I am also using the OEM AAR for cold start fast idle. So, a pretty simple setup. Anyway, the car runs well, I can drive it on the street and it pulls strong so I feel pretty good about the VE table. I just can't quite nail the cold starting. Once the temperature starts getting below 50 or so it can take a couple of cranks to stay started. If it gets down to 30 it can take three or four times. It will kick to life and almost immediately die. Then after the second, third or fourth time it will catch and the AAR will bring the idle up to 1600 and after a few minutes settle back down to 900, running smooth the whole time. I just wanted to list my basic settings and see what you guys think.
required fuel - 18.6 (183 c.i. engine with 180 cc/min injectors)
cranking settings:
priming pw - 2.0
-40 degree pw - 16.0
160 degree pw - 4.0
flood clear threshold - 70.0
cranking rpm - 300
afterstart enrichment:
additive enrichment - 60
ignition cycles - 250
warmup enrichment:
(degrees - enrichment)
00.0 - 200
20.0 - 182
40.0 - 165
60.0 - 150
80.0 - 138
110 - 123
130 - 114
155 - 106
165 - 100
I also have a small enrichment for intake air temp. It's about 12% at zero degrees and tapers linearly to nothing at 75 degrees.
Anyway, thanks in advance for your help :-)
Mine is much less aggressive and starts quite a bit lower. What is your AFR when it catches? I would run a log and see if it is running too lean or rich when it catches and then look at the events afterwards if you really want to solve it.
For priming pw:
-40     14
~60    5
170    2
^That is a bit irrelevant. I was told that the value is basically to purge the injectors of any air, not really an attempt to get fuel into the cylinders.
ASE:
-40     60
-20     52
0        45
20      40
38.4   45
57.2   28
79.1   21
106.6 15
137.9 8
170    5
^Yours looks to be about double mine.
WUE:
-40    190
-20    180
0        160
20     150
40     139
60     133
80     126
100   120
140    109
170    100
^Seems like yours is also a bit higher here as well.
I started my car to move it earlier today, it said it was 1* C in the car and it fired up after about 20 seconds of cranking or so, keep in mind my car is a 3 liter toyota motor with low compression. I think you are putting quite a bit of fuel in there and potentially washing out the cylinders and lowering some compression. Might be helpful to run a compression test and see how it is. A data log of the start will also tell you when the motor catches and why it dies, whether it ran to rich and choked itself out, or the catch was just a detonation from running extremely lean. I would bet it is the former and that when it catches and then subsequently dies it is running quite rich.
Edited by seattlejester
I'll check tomorrow when I get home from work but it seems like when the O2 sensor comes on line the AFR is at about 12. I realize that is rich but I didn't figure it was out of line since my understanding is that even at operating temperature the AFR is supposed to be a bit on the rich side. I figured with the cold temp enrichments that low 12's was reasonable. My AFR at operating temp is about 13.5, by the way. It sounds like your hunch is that I'm a bit rich and you may be right. I'll try leaning out the cranking and afterstart parameters a bit.
Edited by 74Adam
12 isn't all that rich. I was thinking like 10 or something. My car starts and hits about 12-13 then idles around 14 or so. It dips down more when in use, but idle can be on the leaner side generally unless you are boosted or need the extra fuel.
I would take a log and examine that before changing anything by too much. Also remember not to change values too drastically, take it slow.
Turbo280z has a cold start settings video on youtube.. His old turbo 280z setup.. I used his and they worked on my old L28nat setup..
Cygnus1 has his settings on youtube also. i would check those videos out and compare..
Both guys are members on this forum
