Grandpa 1 Posted January 16, 2016 Share Posted January 16, 2016 Which oil pressure sensor should I use? It's for 4.8 and I'll be running a carb. Will a stock one work to also act as a fuel pump cutoff? I know for a gen 1 small block you use the Chrysler set up. Quote Link to comment Share on other sites More sharing options...
LanceVance Posted January 16, 2016 Share Posted January 16, 2016 Not sure about your stock sensor, but this is the sensor and wiring schematic I'm planning on using: http://www.how-to-build-hotrods.com/electric-fuel-pump.html Quote Link to comment Share on other sites More sharing options...
