dpascual1986 Posted March 25, 2016 Share Posted March 25, 2016 I need help finding this part... does anyone know what it is called and where I can buy it? I have a triple carb set up but I would like the half moon part on the linkages. this is the original picture. bell crank? Quote Link to comment Share on other sites More sharing options...
1969honda Posted March 25, 2016 Share Posted March 25, 2016 (edited) Bell crank would be the proper term, some might call it a throttle cam. If you want stock you might try ztherapy and putting up a wanted post on the classifieds. Jenvy or efi hardware might have a solution that works for you as well. Edited March 25, 2016 by 1969honda Quote Link to comment Share on other sites More sharing options...
Metro Posted March 28, 2016 Share Posted March 28, 2016 It seems like all the manifold kits come with one, except the one I bought. I ended up taking a bell crank off a throttle body and welding it to one of the keepers at the end of the rod. Now that I have Jenvey ITBs I'm using their progressive cable pull that mounts to the carb/throttle body. Their kit might work if your carbs have the same diameter throttle shaft and orientation. Quote Link to comment Share on other sites More sharing options...
