Guest Anonymous Posted November 28, 2001 Share Posted November 28, 2001 Ok Kiddies I have a question .I decided on heads cam combo.Leaving bottom end alone .I have a stock LT1 what is the max lift ,duration I can go for a solid cam?? I've heard 610,244 .Iam look at a comp cams extreme energy 12-772-8 242,248 @50 .570 , .576 cam .yes no maybe so?? Quote Link to comment Share on other sites More sharing options...
John Scott Posted November 29, 2001 Share Posted November 29, 2001 I think that is the same grind CC recommended for my 383 with 10.5:1. 2500-6500. I'll be upping the lift for mine closer to .600, but I like the duration and 110 LSA #s. JS Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 29, 2001 Share Posted November 29, 2001 with a 383 you should go healthier more so than you R Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 30, 2001 Share Posted November 30, 2001 Cerberus unless you get new springs and rework the valve guides and spring seats theres no way that a stock chevy springs on a stock LT1 head will work with a lift of over about .530 and thats at coil bind! with no clearence at all!CHEVY SAYS THAT YOU CAN,T EVEN USE THE HOT CAM WITH ONLY A .525 LIFT WITHOUT CHANGEING SPRINGS! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 30, 2001 Share Posted November 30, 2001 not worried about springs. least of my worries .Just don't want too touch bottom end .Was gonna get the trimmings Quote Link to comment Share on other sites More sharing options...
