Brake clutch pedal assembly??
This is a racing, non-power assist setup for dual brake masters and clutch hydraulics, not anything like a direct replacement. You would have to do a lot of fabrication to make that box work in your car.
The only difference between the manual and automatic pedal assemblies is the pedals themselves. You should be able to buy the pedals and swap them into your pedal box.
If you can't find pedals for sale separately, you can swap the whole box out, or buy a used setup and take the pedals off and install in yours. I know there are differences in the pedal boxes from different years, not sure what they are exactly, but that would be the thing to check.
