endofzworld Posted July 2, 2016 Share Posted July 2, 2016 Okay so today I replaced my brake booster and stupidly I disassembled the clutch pedal before I realised it was the wrong one. So I put it back together and finished the brake booster. Went to go for a test drive and it won't go inow to gear. Clutch ras Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted July 5, 2016 Share Posted July 5, 2016 Maybe you've already done this but, not knowing, I'll say it anyway. When your clutch pedal is resting all the way back in it's normal position, adjust the threaded rod that goes into the clutch master cylinder so there's just a tiny amount of free movement in the pedal before it starts pushing on the piston in the clutch master. That way you know you're getting full movement of the piston in the master cylinder. If that doesn't do it, and there's no leaks, it's either your master cylinder or slave cylinder that's the problem (assuming you bled it correctly). Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
