Fuel lines: steel or aluminum
I know this is an old subject, but I want to give the new guys (you old guys too) a chance to pipe up. After all, the population here has almost tripled since I showed up.
I planed on using the original lines. Flare the ends and use -6 AN fittings and steel braid. I'm running a stock '91 305tpi. The TA it came out of had 3/8 & 5/16 lines. The Datsun lines are a size smaller but I figured, eh, they're already there, one less thing to do. Well, that 1/4 line don't flare well. Kept splitting. Pretty soon it was too short. So, rats, I tore it all out and now it will be the right size.
So, please, offer up your experiences and wisdom and tell me which way to go: steel or aluminum? And where did you run it, same place as stock?
BTW, for those of you that haven't seen it yet: http://members.home.net/zcarphotos/djv8zproj/pages/fbs01r16f25rw.html
Here is my advice:
If you are going to replace your fuel lines, do it while the motor and tranny are OUT. Big, greasy, difficult job. If I thought there was any other place to run them as safe as the original location I'd do it.
Hear what you say about steel. This was difficult enough in aluminum. I would think it would be imposible in steel with the motor in.
Dan
