brakes pressure regulator valve 78 datsun 280Z
after removing the above mentioned valve from my firewall and unable to find a replacement or a rebuild kit, I decided to
take it apart and clean.  I notice after removing the top bolt head it is connected to a machined internal part that has a
grove cut into it and inside the grove their is a drilled hole through the shaft.  To me it looks like a rubber O-ring fits into
this grove, does anyone know if an O-ring is needed.
