Waders Posted November 3, 2016 Share Posted November 3, 2016 My window crank (A) came off the gear (B.), the spring is still in but I dont know if i can push against the spring and fit the crank (A) back in where the teeths (B.) are without taking it out of the door panel. Its hard to explain, look at pictures. Thanks in advance for the help. Quote Link to comment Share on other sites More sharing options...
Villeman Posted November 4, 2016 Share Posted November 4, 2016 (edited) did you remove the hand crank? Or did the connection between the two pinions break? With spring, do you mean that one? http://woodworkerb.com/wp-content/uploads/2014/11/WindowCrank2.jpg Edited November 4, 2016 by Villeman Quote Link to comment Share on other sites More sharing options...
Waders Posted November 4, 2016 Author Share Posted November 4, 2016 Hand crank is removed. Just the big gear with teeth like in the picture, B , came off the crank. Quote Link to comment Share on other sites More sharing options...
Waders Posted November 4, 2016 Author Share Posted November 4, 2016 (edited) The connection between the pinions snapped off. Nothing is broken, as much as I can see. Just wondering how to put it back. And if I can do it without take the regulator out Edited November 4, 2016 by Waders Quote Link to comment Share on other sites More sharing options...
z240 Posted November 4, 2016 Share Posted November 4, 2016 The spring pressure is easy to overcome, it's easy to restart the gears meshing again. Now whether you can do in the door depends on your dexterity and patience. Go play, you'll figure it out. What year Z are we working on? The 77/78 regulators and window track systems are unique, and the advice will vary about getting the window out if you need to do that. Quote Link to comment Share on other sites More sharing options...
Waders Posted November 4, 2016 Author Share Posted November 4, 2016 77 280z, Do I need to crank the regulator to get it to grip the meshing. Ive tried and tried to get it in without cranking but cant. Thanks for the advice by the way, really appreciate all the help Quote Link to comment Share on other sites More sharing options...
z240 Posted November 4, 2016 Share Posted November 4, 2016 yes you would have to turn the handle to get the gears to mesh. I have a couple of really good regulators for you if it goes there. Shouldnt, just have to get your gears to mesh. Quote Link to comment Share on other sites More sharing options...
