98blackbell Posted February 1, 2017 Share Posted February 1, 2017 So this happened. See pic. We reconnected the wires and now we have no crank signal or advance. All fuses are good. Did we burn up the module in the distributor? Or something else. The ecu communicates with laptop. This is megasquirt, coil pack turbo. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 1, 2017 Share Posted February 1, 2017 Those look like CAS wires. With coil-packs, the distributor function is gone, so that's not the right word. The modules are a bit sensitive, I think. Here's a vendor. http://forums.hybridz.org/topic/121493-new-crank-angle-sensors-for-8283-280zxts-in-stock/ I've dinked around with later models (Pathfinder VG30E engine) and found that some people swap newer for older. I don't know which comes on the 280ZX CAS's though, so don't know if this is relevant. Here's an example. RSB-07 replaces RSB-03. https://z31performance.com/forum/z31-basics/how-to-guides-basic/20433-rsb-07-cam-sensor If you have another car that uses that type of CAS you can plug in the questionable CAS to the good car, turn the key to On, and spin it by hand. If it's good the injectors will click. An easy way to tell if it's ECU or CAS. Quote Link to comment Share on other sites More sharing options...
98blackbell Posted February 2, 2017 Author Share Posted February 2, 2017 Good option for replace and better electronics. Son picked up an 83 Datsun maxima. Will try the testing on that car. Quote Link to comment Share on other sites More sharing options...
