VitaminZ Posted August 5, 2017 Share Posted August 5, 2017 (edited) Ok , I've tried searching for this specific problem but couldn't find anything , for some reason my turn signals won't flash when I turn the headlights on , the turn signal light on the dash just stays solid. They work fine with the headlights off . I tried changing the turn signal relay but still doesn't work . I have a 72 240z stock harness . Any help is appreciated .. Edited August 5, 2017 by VitaminZ Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted August 6, 2017 Share Posted August 6, 2017 I've see that happen when an 1157 bulb was either installed 180 off or the socket was causing the parking lights to backfeed up the turn signal wire. Quote Link to comment Share on other sites More sharing options...
VitaminZ Posted August 6, 2017 Author Share Posted August 6, 2017 Thanks , yeh I realized I had the wrong bulb in there . On 8/6/2017 at 1:11 PM, HowlerMonkey said: I've see that happen when an 1157 bulb was either installed 180 off or the socket was causing the parking lights to backfeed up the turn signal wire. Quote Link to comment Share on other sites More sharing options...
