To Die For
Scottie-GNZ
Your nuts have to go clank when you strap yourself in this short wheelbase rocket. Regardles, what a gorgeous car. For the uninitiated, a Buick Stage2 motor is the one to die for. It is the one used in the Indy Car program and 1000+hp is common.
http://www.turbobuick.com/bb/Forum13/HTML/008943.html
Scottie
71 240GN-Z
Scottie's GNZ
The Opel GT!! I was going to buy one the other day for 500.00 but I have to many projects in the works! I used to drive an
Opel Manta in high school and I had a
blast in that car!... they are very light
and handle quit well. The headlights roll
over and are actuated with a large handle
inside the car. The stock 4 cyl motor sits
way back in the car and it would take alot
of mods to put in a V motor.. I was
thinking hard about doing a swap in one..
Myron
Always liked the Manta and Opel GT. A guy used to come into the gas station I worked at in high school (back when attendants had to roam around the pumps to collect gas money) had one with a V8 in it. SWEET!
The intercooler pipe feeding that Stage 2 is what, 5" diameter!? Tell us about it, Scottie! Hell of a Hybrid
Judging from the Moster tach on the dash, I would agree that is a 5" up pipe. Here is what I know about the car:
It weighs 2705lbs w/driver. It has a mild-steel tube frame with 100.5" wb. Plans are to redo the frame to 25:1c specs and stretch the wb to 112". I am surpised at the current weight.
The engine is a twin-turbo 274ci Stage2. The car does not have a lot of passes on it and the reported best is 1.22 60' (HOLY SLINGSHOT!) and a 7.97 ET. Do not know the mph, but I would guess at low-mid 160s. That was done at a somewhat conservative boost level of 28-29# with the RPMs limited to low-8000s. With a little more boost and higher RPMs there is more, but my cabobulator melted down at 1004rwhp. With a little more power and less weight, it should go....... eek.gif. He is going to need that extra wb.
I supposed Ron could relate somewhat.
I know the Opel GT's nose looks like a Vette, but from the base of the windshield back, it is pure 1st-gen Z-car.
Scottie
71 240GN-Z
Scottie's GNZ
  • 3 weeks later...
