Engine weights
CruxGNZ
I need to get spring rates for my coilovers, so I have to figure out how much I will be adding to the front end of my Z compared to a stock Z. From what I gathered, the Buick V-6 with the turbo and trans. weighs around 560 lbs., give or take a few. What I haven't been able to find is how much the engine and trans weighs from a stock Z. Anyone know?
Scottie, maybe you could help me out. What rates are you running? My car will see 80% street, 20% track (raod course/1320). I will have a full interior and a hefty stereo in the rear. In the future, I will put air conditioning in, but I don't know yet if I should go ahead and buy a higher rate spring just because I am going to add more weight down the road.
Any help would be great.
!M!
ENGINE DIMENSIONS
all lengths are in inches, weights are in pounds
C.I.D. WIDTH LENGTH HEIGHT WEIGHT
CHEV V6 200 26W 24L 27H 400 lbs
V8 262,265
283,302
305,307
327,350
400 26W 28L 27H 575lbs
348,409 28 1/2 34 1/2 32 685lbs
396,402
427,454 28W 30 1/2L 29H 685lbs
FORD V8 221,260
289,302
351W 24W 29L 27 1/2H 460lbs
232,292
312 28W 29L 29H 625lbs
302 Boss 24W 29L 29H 500lbs
351C 24 1/2W 29L 28 1/2H 550lbs
332,352
390,406
410,427 27W 32L 29H 625lbs
427 sohc 32W 34L 29H 680lbs
429,460 27W 30L 29H 720lbs
429 Boss 28W 34L 30H 635lbs
MOPAR V8 273,318
340,360 24W 29L 27H 550lbs
361,383
340,413
426,440 29 1/2W 30L 29H 670lbs
331,354
392 29W 31L 31H 765lbs
426 29W 32L 32H 690lbs
BUICK V6 198,225
231 26W 23L 28 1/2H 400lbs
231 Turbo 30W 23L 30H 430lbs
215 Aluminum 26W 28L 27H 320lbs
350 28 1/2W 30 1/2L 28 1/2H 450lbs
401,425
Nailhead 28W 33 1/2L 29H 650lbs
400,430
455 28W 30L 30H 600lbs
CADILLAC V8 472,500 28 30 1/2 28 600lbs
OLDS V6 198,225
V8 215 Aluminum 26W 28L 27H 320lbs
260,330
350,403 26W 28L 27 1/2H 560lbs
303,394 30W 32L 29H 700lbs
400,425
456 26 1/2W 31L 29H 620lbs
PONTIAC V8 215 Aluminum 26 28 27 320lbs
301 25W 32L 30H 475lbs
326,350
389,400
428,455 25 1/2W 32L 30H 640lbs
--HEIGHT IS FROM AIR CLEANER TO PAN--
--LENGTH INCLUDES WATER PUMP--
--WIDTH INCLUDES HEADS, VALVE COVERS,MANIFOLDS--
I believe the L6 is about 420lbs, then add the flywheel, clutch, about 75lbs for the trans and that should make them about even. However, keep in mind that entire Buick engine will be behind the front wheels.
I have uprated front springs but do not remember the rate. My rear spring is 160# but I lean towards 1320. Having adj shocks allow me to go full soft at the strip and medium on the street. If you are 80/20 then go for the 80% but keep in mind that stiff springs are not good for drag racing especially if you have a lot of power and sticky tires. Wheelhop!!
