A/C removal question
I'm going to remove my non-working a/c unit in my 75 280z. I did take a look at the FSM and it seems pretty simple for the engine bay but i wanted to confirm i could remove both the compressor pulley and the idle pulley as well - leaving only the (1) belt for alternator and water pump.
thanks
The compressor and the idler pulley both mount to the same bracket, and that pulley is only there to adjust tension on the compressor. You can remove all of them with no issues.
It'll be a lot more obvious once you're there looking at it.
Expand
Awesome! Thats exactly what i was thinking but didn't want to under-think it.
