77 280 how to set wiper linkage to park
With the linkage not attached and new motor plugged in turn the wiper switch on for a few seconds then turn it off, the motor will stop in the park position. With out turning the motor from where it is attach the linkage so that it is in the park position as well, once motor and linkage are installed and working attach you wiper blades also in the park position. Test it out with your blades raised or with water on the windshield so you are not taxing the motor.
While you have the linkage out make sure you overhaul the spindles that move the wiper blades, they can get very stiff with corrosion.
