Help! Buzzing noise and no power?
kaiserser
Hi Guys,
I had pulled my engine to do some work on it and when I put it back in and attached the battery leads, I started getting this buzzing noise coming from the console area and nothing else seemed to be getting any power.
I figured out the buzzing noise was coming from a little brass  box in the console area to the left of the fuse panel. From what I can tell it seems like a relay of some sort with three prongs and a fitted plug with 3 wires connected to it, but no part numbers on it.
A few specifics:
The buzzing is 100% is coming from inside that little box that seems to be a relay.
If I unplug that box/relay, the sound immediately stops, but I still have no power to lights/ignition etc
If left plugged in, the buzzing noise persists regardless of key position. .
Three wires plug into this box/relay but I can't tell where they come from.
If anyone knows what might be causing this weird scenario I would really appreciate your  help!
Thanks,
Jon
