TheWeekendWagon Posted September 27, 2018 Share Posted September 27, 2018 Looking for the rubber grommet that goes around the heater hoses on the firewall. Anything from a '75-'78 Z should fit. I don't need the metal cover just the rubber piece as mine crumbled into pieces when I took it off. Quote Link to comment Share on other sites More sharing options...
wal280z Posted October 22, 2018 Share Posted October 22, 2018 I don't have that piece, but will offer the knowledge of UP TO 1995 Pathfinder / D21 pickup trucks used nearly identical AC grommet blank-off and pass-through bulkhead grommets. The heater grommet you are looking for LOOKED similar, but it also crumbled upon attempt to remove it, whereas the AC grommet must have used a different compound. In the picture below, the top grommet was removed from a 1995 Pathfinder. The middle blank-off grommet was removed from a 1993 D21 pickup The bottom grommet is stock to the Z. Quote Link to comment Share on other sites More sharing options...
TheWeekendWagon Posted October 22, 2018 Author Share Posted October 22, 2018 Oh man, those look identical. Unfortunately I ended up grossly over-paying for a new one from JDM-Car-Parts.com. Awesome that they have new ones but yeah I am sure I could have snagged a much cheaper junkyard pull from one of those. Great info though! Quote Link to comment Share on other sites More sharing options...
