MOJO13 Posted December 15, 2001 Share Posted December 15, 2001 I have a T5 and a 79 Chevy 350 engine and I am having trouble finding a starter that lines up properly. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 16, 2001 Share Posted December 16, 2001 I'm assuming you have T5 with a 153 tooth flywheel. I have the same and use a medium-duty starter I found on a 305 V8 Camaro. According to JTR, you should be able to use a heavy duty starter that came on the 153 tooth flywheels on 1982-1992 V8 Camaros with automatic transmissions. HTH, Davy Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted December 16, 2001 Share Posted December 16, 2001 You also might want to look into one of those high torque mini starters from Tilton or the like. They have a double bolt pattern that will allow you to use it with a 153 or 168 tooth flywheel. They are also impervious to the hot starter - no start problem that Chevy starters are famous for. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 16, 2001 Share Posted December 16, 2001 hes right , i have a mini hi torque tilton, man that thing will crank in any weather after heated long driving sessions after about two seconds, its bad, and yeah, chevy starters do love to hate you after they get hot. Quote Link to comment Share on other sites More sharing options...
