Adjustable rear lower control arm (LCA) - how much shorter than stock?
Does anyone happen to have any information on any adjustable lower control arm lengths?  I need a control arm shorter than stock, but not by much.  This is for a custom project, so the other components of the suspension/drivetrain/body is taken care of except for this last bit.
I need the control arm to be at least 12mm shorter, or ideally, 13.35mm shorter (max).  Basically, if any knows if any brands of adjustable lower control arms can go positive direction for camber, and by how much shorter, that would be great information.  Thank you!!
Edited by RT Hunter
