thisismatt Posted March 18, 2020 Share Posted March 18, 2020 Hey all - I have a VQ35DE/HR fuel pump (17040-EV10A) that I plan to drop into a stock Datsun fuel tank for my VQ swap. I can't seem to find any info regarding the internal in-tank fuel line that goes from the pump across the hump to the other side of the tank in the 350Z/G35 stock tank. This hose doesn't seem to be sold separately as far as I can tell. Do I need this secondary line? Can I leave it disconnected? Should I just cap it since the pump will be submerged in an otherwise flat bottom tank? I've attached a picture showing the hose that I'm talking about (cut off - not my pump). Thanks for any help Quote Link to comment Share on other sites More sharing options...
260DET Posted April 3, 2020 Share Posted April 3, 2020 It has to be either a vent or return hose doesn't it, for a more definitive answer maybe try the 350Z forum. Quote Link to comment Share on other sites More sharing options...
thisismatt Posted April 4, 2020 Author Share Posted April 4, 2020 23 hours ago, 260DET said: It has to be either a vent or return hose doesn't it, for a more definitive answer maybe try the 350Z forum. From what I can tell it's just a feed from the other side of the trans/driveline tunnel, but if the pump wants to draw from both simultaneously, then it seems like I should at least run it to the bottom of my tank as well... Quote Link to comment Share on other sites More sharing options...
