NCchris Posted May 17, 2020 Share Posted May 17, 2020 Hello! Let me first say that I have searched for an answer and no luck. I was wanting to use a 3 AN bulkhead fitting to go through the inner fender since the flex line to the calipers is 3AN. The 3/16 hardline can be connected to the other end of the bulkhead fitting using a tube fitting and a nut. The hardline will need to be flared 37 degrees to match the AN taper. Herein lies my question: does this 37 degree flare need to be the double flare as the rest of the fittings in the car? TIA, Chris Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 17, 2020 Share Posted May 17, 2020 AN uses single flares, not double. Chamfer the ends of your tube before you flare (very important!), then use a magnifying glass to inspect for cracks. Quote Link to comment Share on other sites More sharing options...
NCchris Posted May 17, 2020 Author Share Posted May 17, 2020 Thanks Jon, that's what I thought! Quote Link to comment Share on other sites More sharing options...
