WailordUseBodySlam Posted May 18, 2020 Share Posted May 18, 2020 Does anyone know which (if either of these) line up better with an LS swap. Just planning it out, so still learning so forgive me if this is a dumb question, I did find this though. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 21, 2020 Share Posted May 21, 2020 Ironhead installed the Magnum which put it about 4" forward of stock shifter hole in tunnel. I think the Magnum-F with shifter location 3" father toward the rear compared to Magnum will best match up with stock shifter hole. Have a look at Ironhead's build thread, he has a few good pics of installed Magnum. By the way, I will most likely be using a Magnum-F in my LS build because of the better fitment. I am curious why it is listed at $200 more then the other Magnum models... Quote Link to comment Share on other sites More sharing options...
WhiskeyZ Posted May 2, 2021 Share Posted May 2, 2021 @280Z-LS3 Did you end up going with the Magnum-F - how was the fit with the LS3 and shifter hole? Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 2, 2021 Share Posted May 2, 2021 13 minutes ago, WhiskeyZ said: @280Z-LS3 Did you end up going with the Magnum-F - how was the fit with the LS3 and shifter hole? Look on my build thread for some good pics and discussion of trans in tunnel. Quote Link to comment Share on other sites More sharing options...
