RCVTR Posted March 13 Author Share Posted March 13 (edited) Attaching the rear section was pretty straightforward. Edited March 13 by RCVTR Quote Link to comment Share on other sites More sharing options...
jhaag Posted March 14 Share Posted March 14 Impressive craftsmanship! John Quote Link to comment Share on other sites More sharing options...
A to Z Posted March 16 Share Posted March 16 Wow. Good job. that's a lot of work! Quote Link to comment Share on other sites More sharing options...
RCVTR Posted March 17 Author Share Posted March 17 Thanks for the positive feedback! It's all a matter of commitment, deciding on the best plan we could come up with and then figuring out how to do it. If we didn't have each other to bounce ideas off of and keep each other fired up, it probably wouldn't have happened. So, now that the body was back together, The outer wheel tubs were mildly crushed and we wanted to put wider wheels and tires on. So the next phase was preparing the rear fenders for ZTrix Subtle Z bodywork. We had the body, now comes the work. To fit wider wheels, you have to modify the fender opening and wheel tub, so that the tub is at it's maximum height out past the fender opening: Quote Link to comment Share on other sites More sharing options...
A to Z Posted March 17 Share Posted March 17 A lot of progress! finding the motivation to keep going is key. A lot of projects stall and never get finished. Quote Link to comment Share on other sites More sharing options...
RCVTR Posted March 27 Author Share Posted March 27 Z Trix bodywork was a custom fit all the way. We trimmed the rear fenders along the top shoulder, then scarfed the back side along the edges to get it to blend into the existing panel. Applied a seal coat, then bonded them on. The front fenders required quite a bit of work to get the hood gaps right. Lots of small problems to solve, but it came out well. I'll let the photos tell the rest. 1 Quote Link to comment Share on other sites More sharing options...
RCVTR Posted March 31 Author Share Posted March 31 The right side door had rust along the bottom edge seam, indicating that the door skin had probably been replaced and the seam was rotting out. So we folded the seam open and removed both door skins and the 11 lb. door beams. Blasted away the rust, fast-etched and painted the inside with rust encapsulator paint and sealed the seams with epoxy and folded them back. 1 Quote Link to comment Share on other sites More sharing options...
