Was Working...now no spark and ballast resistor hot
I have a 72 240z with a L28 and 280z distributor.  All was working in the ignition department and she was driving.  Took her out for a drive and then she sat a few days and not there is no spark.  Now when I have the key on the ballast resistor and ignition coil are getting hot.  Ant suggestions?
I do have a question about one wire that is not being used and it looks like it may go to the where the distributor mounts.  Should it be hooked up?
I bought the following:
PerTronix Flame-Thrower II
New Distributor Pickup Coil
Rotor & Cap
I want to run the PerTronix Flame-Thrower II so I can remove the ballast resistor.
The coil and resistor would be getting hot because they have current flowing through them.  That would be because there is a short circuit on the wiring after the coil negative terminal.   Looking at all of those exposed connections, that would not be a surprise.
If you can't find the bare wire or connector that is shorting to ground, your ignition module might be bad.
That spade end is just connected to ground.  There's a wire that needs a ground somewhere.
