Conversion from 6 bolt CV hub to 280z half-shafts
Hi all!
I found an OEM S15 Spec-R and accompanying companion flanges for a reasonable price. looking over the forums, it should bolt in (possible requiring 10-12mm bushings) to my existing ring gear. I'm still running the 280z halfshafts. Ideally I would go full CV, but the cost of fresh custom length axles and hub/adapter looks quite expensive. Is anyone aware of a 6-bolt axle flange to 280z half-shaft adapter? The 6-bolt arrangement is like the below picture.
This is for an L24. With the head modifications underway, I don't expect to see more than 155-165 ft-lbs of torque so that wont be a factor. This is for the SCCA group EP race car.
