clint78z Posted May 9, 2001 Share Posted May 9, 2001 Argh I went to the junkyard to get a 300zx throttle body for my 280zxt motor. I got one off an 84 300zxt, it's good except it's switch type TPS. So the next weekend I swap it for an 88 300ZXT TPS thinking it would be potentiometer type, nope. Is it only the non turbo's that used the Potentiometer type that I need for my Accel DFI fuel inkection. Scottie what year and make did you use?? Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 9, 2001 Share Posted May 9, 2001 Boy, you are really taxing my memory here. I recall getting mine off an 86 NA but also remember pulling one off the turbo that I got my LSD from so that would make it 87+. That one I put on the Mustang 60mm TB, however, I never hooked it up. Remember the TPS is used by SDS as a signal for giving an extra squirt of fuel off-idle, sort of like an accelerator pump. I was also under the impression that all cars used the potentiometer-type after 84. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 10, 2001 Share Posted May 10, 2001 My '87 300ZXT ECU uses the switch type TPS, and I'm pretty sure I saw in the FSM the N/A model uses the same. I've never seen a pot type TPS on any Z or ZX, but I'm not saying they didn't. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted May 10, 2001 Share Posted May 10, 2001 The 88? 240sx throttle body I have uses a potentiometer type TPS... Not sure if it'll adapt to your use, but I would imagine you could find a junkyard TPS that will do ya. Quote Link to comment Share on other sites More sharing options...
clint78z Posted May 10, 2001 Author Share Posted May 10, 2001 Thanks for the quick responses, I guess I will have to do some hunting. Struck me as rather odd that the 88zxt was still switch type. Long weekend coming up, time to light a fire under that engine and get it stoked up. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2001 Share Posted May 14, 2001 i used a nissan sr 20 throttle body which is a potentiometer type. actually it is very similar to a 240sx throttle body. i had to order the switch but i got it at autozone for around 60 or so. happy hunting. Quote Link to comment Share on other sites More sharing options...
