Dondo_Z Posted March 28, 2021 Share Posted March 28, 2021 (edited) I recently purchased a "ran when parked" 73 with a 350 swap. auto trans. I installed a known good battery and when i turned the ignition switch, the starter would spin but the bendix would not engage. I disconnected battery and then I took a long prybar and taped the starter and starter solenoid. Reconnected power, then I no longer had power at the ignition switch. I have 12.4V at the starter. I have continuity from the "S" terminal to IGN SW BY wire. But I have no 12V at the IGN SW RW wire. or anywhere really. not at the fuse box either. I found the a fusible link that is not connected to anything located near the starter. The connector is broken. is this still used in a V8 swap? Momentarily touching this to the postive starter terminal shows no change. I am using earlywire.JPG (2800×2031) (airmayer.com) for tracing wires. Where should I expect 12V when the car is in off? ACC? ON? I have been staring at this diagram and will be testing W at the fuse box after repairing the fusible link and connecting it to the starter terminal. unless for some reason this is not used anymore. Thanks for any help. I can use a meter and test light and do have mid level mechanical experience. will get photos up in the morning, Thanks Dondo-Z Edited March 28, 2021 by Dondo_Z Add photos Quote Link to comment Share on other sites More sharing options...
Dondo_Z Posted March 28, 2021 Author Share Posted March 28, 2021 Update, fusible link replaced all power restored. starter still having issues with bendix gear. its jumping out but grinding the fly wheel. Will remove have tested and replaced. Quote Link to comment Share on other sites More sharing options...
Michael Posted April 21, 2021 Share Posted April 21, 2021 Turn everything off, put transmission in neutral and spin the crank (via crank pulley bolt) with the appropriate socket wrench (7/8", if memory serves) and either a breaker-bar or a section of pipe engaged with the wrench handle. Spin the crank for a full revolution. It is possible that the crank is seized, whence the starter can't muster enough torque to break the seizing. If the crank is indeed seized, that's problem #1. If it spins OK by hand, then we'll return to the starter problem. A vigorous person should have no difficulty turning the crank with the spark plugs installed and normal compression. But if you're struggling, or in doubt, remove the spark plugs (all 8). With plugs removed, a small block crank should spin with no more than around 25 ft-lb of torque. Check with a torque-wrench. If the torque is higher than that, there may be a problem. It may also be worthwhile to try to "start" the engine with the plugs still removed. Just don't spin it for too many revolutions, as that soaks the cylinders with raw fuel. Quote Link to comment Share on other sites More sharing options...
