My new intercooler pictures
Really nice. I see you did the end tank pieces with a press brake (versus slip rolls) they look great. Very nice work.
Regards,
Lone
James, i noticed that you have 3" inlet are you going to keep that 3" to the engine and i also noticed you have inlet and outlet on the same side, where is your air filter going to go? are you going to be placing any ducts to direction the air into the intercooler?
Chase, the inlet is 2.5" and the outlet is 3". My TB is a 70mm unit and the inlet is approximately 3" No reason to run 2.5" pipe to a 3" opening on a TB. I am only interested in all out flow and because of my stall I skip all the low end BS. The intercooler will sit front and center so no ducting is needed. I will place a 3" lip around the core itself to isolate all air coming into the core so it cannot escape. It is said to improve the effeciency about 5%. Because I run the inlet tube through the wall of the engine compartment, I have extra room to run the filter up front as I did on my old setup.
