lotussutol Posted December 27, 2022 Share Posted December 27, 2022 The early CTS-V T56 have an odd shifter location way further back from a normal T56. Have any of you used one of these in a swap and used the direct bolt in shifter location (further forward) and corrected that with an offset shifter to the rear? I found a company that claimed to put the shifter in the stock T56 location but now for the life of me I can't find it. Still looking. I guess the question is...have any of you used this t56 and what shifter did you use or did you change the tail housing route? Quote Link to comment Share on other sites More sharing options...
berton Posted June 8, 2024 Share Posted June 8, 2024 On 12/27/2022 at 7:47 AM, lotussutol said: The early CTS-V T56 have an odd shifter location way further back from a normal T56. Have any of you used one of these in a swap and used the direct bolt in shifter location (further forward) and corrected that with an offset shifter to the rear? I found a company that claimed to put the shifter in the stock T56 location but now for the life of me I can't find it. Still looking. I guess the question is...have any of you used this t56 and what shifter did you use or did you change the tail housing route? I have ls and t56 out of a 04 ctsv in my z. I have the apex crossmember and the engine is maybe 2-3” away from the firewall. I have only mocked up the factory shifter linkage and it looks like it’s going to be in a pretty comfortable position. However I will have to cut up the trans tunnel. I will try and post pictures Monday to give an idea where about the factory shifter lands Quote Link to comment Share on other sites More sharing options...
berton Posted July 13, 2024 Share Posted July 13, 2024 On 6/8/2024 at 4:59 PM, berton said: I have ls and t56 out of a 04 ctsv in my z. I have the apex crossmember and the engine is maybe 2-3” away from the firewall. I have only mocked up the factory shifter linkage and it looks like it’s going to be in a pretty comfortable position. However I will have to cut up the trans tunnel. I will try and post pictures Monday to give an idea where about the factory shifter lands Not sure if this is still needed or relevant but here are the pics! Quote Link to comment Share on other sites More sharing options...
christianmoller Posted July 14, 2024 Share Posted July 14, 2024 Hello, Picture is all black for me. I'm also interested of what the linkage looks like as i thinking of going that route instead of the F-body way. /C Quote Link to comment Share on other sites More sharing options...
berton Posted July 14, 2024 Share Posted July 14, 2024 5 hours ago, christianmoller said: Hello, Picture is all black for me. I'm also interested of what the linkage looks like as i thinking of going that route instead of the F-body way. /C I’m pretty sure the ctsv shifter is unique to itself and puts the shifter pretty far back. I had to cut the trans tunnel. I will retry posting pics. The first one is just from google of the shifter linkage. And the second two are where it landed in my z Quote Link to comment Share on other sites More sharing options...
berton Posted July 14, 2024 Share Posted July 14, 2024 (edited) It doesn’t like my images hopefully this google image link works https://photos.app.goo.gl/GfKMSguQd2BaYS4H7 the order is different then I mentioned but should be obvious Edited July 14, 2024 by berton 1 Quote Link to comment Share on other sites More sharing options...
christianmoller Posted July 15, 2024 Share Posted July 15, 2024 Thanks Berton, I have tried to locate the part in the red circle, what is it called, cover, lid ,base?!?. What is the height of this part? Cadillac don't exist here in Sweden so to find one i must look in US. Quote Link to comment Share on other sites More sharing options...
