Turbo Sled Update (With Pictures!)
Thanks lone that was quick!I didn't get a chance to drive it last night i wasn't feeling good so i just snapped some pics and sent them to you.Guys don't mind the flex tube to the carb it's getting changed soon i just wanted to see if it would work before i spent the money on a custom pipe.When i had it running it seemed to have alot more power.But i'll see soon enough when i take it for a ride around the yard on the grass.Oh ya it needs to be cleaned so don't mind the crap on it i just got it out from storage about a week ago.When it's all done i'll see if lone will post some better ones.This is a total sleeper no one would expect a turbo on a sled especially one this old. icon_smile.gif
Shouldn't need a new carb. What's occuring is the gas is being pumped back down the line under boost. The fuel pressure needs to be pressure refrenced so that as boost rises the fuel pressure will go up at the same rate. This occurs on automotive carbs too. Mechanical fuel pump right? It can be done with those by drillingtapping into the pump but I'm honestly not sure how it's done or how it's done on a snowmobile icon_smile.gif Check around on the 'net and you should find information on how it's done for cars or maybe bikes which should be a clue.
Oh, carb have floats? Make sure they're strong as they could also collapse under the boost. Even a few lbs of boost could put a surprising amount of pressure on the float. icon_smile.gif
Thanks blk but the carb is a tilloston and it has an internal pump in the carb and it requires the pulsation of the engine when it sucks and blows on the engine's normal cycle.I'm just wondering if it's just getting blow instead of both?I'm checking some sites and hope to find an answer soon.I even thought of a fuel injection system.
Scotty,
I'd check with some of the bike turbo places (do a search under like motorcycle turbo) or something to that effect. There are loads of bike carbs to be had, some slide type, some CV carbs like the Harleys (and some Honda's) use. (which I'm not sure will work, but on the other hand isn't that sorta what a SU is?). Probably know all that, but thought I'd tell ya just in case.
How about a carb box? Perhaps if all the vents and such are under pressure as well it'll work? It would require enclosing the carb in a box and sealing where the linkage goes in ala Studebaker.
Just some ideas.
Regards,
Lone
Thanks for the ideas i checked for some sites on turbo sleds but seem to find none i'll have to try the bike sites.The carb is not like a su it's just a plain carb nothing special but i think i will go with a mikuni carb and fuel pump.This is going to get expensive quick i can see it now i just hope the results are worth it. icon_smile.gif
Hrm, presurrize the gas tank perhaps? Use a check valve so it doesn't suck in raw gas icon_confused.gif hrm, not sure you'd be able to work that out.... Pressurizing the entire carb might do it but I'd be afraid it would just push the gas right back into the tank..
Ahh, it'll be fun, it'll winter, you'll be bored. It won't cost ya that much.. icon_smile.gif
Seriously though, if its a motorcycle carb, look for a bike dismantler, save ya at least 50-75%, alot of times particularly on bikes the stuff is real low mileage (except for forks, those are tough to find as most of them have the distinctive oscar meyer weiner look to them hence the reason they're in a dismantler icon_smile.gif ).
Regards,
Lone
Well another update i took some advice and pressurized the carb in the "Bowl" of the carb.It doesn't have a real bowl so i used the fuel return line and it acually worked icon_smile.gif But... yes there is always a but the return line is just actually just putting gas in the turbo and when it spools up it will push in extra gas but i do think it is pushing the gas thru the carb too.I found out my crappy intake pipe from the turbo to carb isn't too air tight it leaks alot.When it gets flooded it will fill the turbo up with fuel and then when i started it it pushed that big load of fuel up the pipe and i saw it leaking out everywhere icon_sad.gif So the next thing is a mikuni carb i think unless i can rack my brain for another idea to use the stock carb.One good thing is the fuel has oil in it and it helps oil the turbo but.... yes another but it is very hard to tune cuz the jets in the carb are set one way and all the extra fuel from the return line is pushed into it too so either i can have good low end or good high end no happy medium.But it does run and stay running and does have more power and sounds sweet when i let off the throttle with that psshhhhh sound. icon_smile.gif Well that's my update for now i think i'll keep on it to try to get a working turbo sled.I lose ambition after a while then i get into it and it gets me excited again and i'm into it again.I have a question too do you guys think that a check valve would work in the return line?I could use it to keep the fuel out but it would let the pressure in what do you think?
Might work ok, maybe like a rollover valve in a fuel cell on a T off that return line (or a check valve more appropriate). *shrug*
Regards,
Lone
