Guest Anonymous Posted February 17, 2002 Share Posted February 17, 2002 With a P90A head on the block can the N/A engine hold 7psi? or what recommendations do you suggest? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 17, 2002 Share Posted February 17, 2002 Is it safe to boost it that high ? I also have a Volvo I/C. THanks, Mark Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 17, 2002 Share Posted February 17, 2002 Where can I get that Metal Headgasket? Quote Link to comment Share on other sites More sharing options...
TimZ Posted February 17, 2002 Share Posted February 17, 2002 Originally posted by stony:2-3mm metal headgasket With the stock N/A block (I'm assuming L28 here), the P90 should yield a CR of about 7.4:1 with the stock head gasket. Going to the thicker HKS gaskets would yield CRs of 6.5 (3mm) to 6.9:1 (2mm), which is too low, IMHO. I'm currently running ~24psi on an N42 block with no problems. I am using forged 7.5:1 pistons at that boost level, though. For the stock cast pistons, 7.4 CR, a decent intercooler and proper fuel delivery and ignition timing, you should be able to run ~12psi (maybe 14) with no problems. If you really want a metal head gasket, then you should use the HKS 1mm gasket, which will yield a CR of about 7.5:1. Quote Link to comment Share on other sites More sharing options...
stony Posted February 18, 2002 Share Posted February 18, 2002 2-3mm metal headgasket Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted February 18, 2002 Share Posted February 18, 2002 I have run up to 17 psi on a 78 n/a block P90A combo using a stock Nissan headgasket with the clutch being the only casualty. I do have a good IC,a SDS a big injectors though. Having enough fuel and the proper timing is the determining factor in how much boost you can safely run. Without the IC I regularly ran 9psi with no ill effects. So to answer your question I would say 7psi is easily doable with stock parts. Quote Link to comment Share on other sites More sharing options...
