more boost problems
v8dats
well since i dicided to keep my turbo car.ive been working on it quite a bit and have done the following......
i installed a fuel pump from the ford van using scotty's method(to the alt,batt.,ect..)new plug wires new tps,cap rotor,fresh fuel.the problem i have is when i drive the car its o.k until i try to give it more gas.it stumbles and jerksbut at certain rmps it pulls very hard and the gauge jumps to 10lbs of boost.i love the way it pulls on SOME rpms.how do i adjust the tps?i love my turbo car(my first)and i have big plans for it
i dont think that its a fuel problem.the car doesnt have the stock rusty gas tank.it has a fuel cell with a new pump.i checked the lines and they look pretty good.
the car also makes a weird rattling sound under boost(sometimes)but thats when its running the best.
my friend thinks that the turbo is about to go and thinks that the wastegate is working properly
any suggestions?
Have you talked to Z Doc over in Tampa, I heard he was really good with turbo problems. If you can't get help there try getting up with Scotty GNZ in Orlando as he knows tons about turbo cars.
260DET is on to something. If you are hearing a rattling sound under boost, STOP RUNNING THE CAR UNDER BOOST for now. That is probably the death-rattle, DETONATION. 2nd thing I would do is buy, beg, steal or borrow a fuel pressure gauge with a line long enough that you can extend to tape the gauge to the windshield so you can see the fuel pressure under boost. You should be able to build one of those for less than $50. I am guessing you are having a fuel delivery problem causing a lean condition. Pull the plugs and see if the engine is running lean.
